SIGMA fp Cinema Camera with CinemaDNG raw
  • 57 Replies sorted by
  • Grate camera, Grate idea, grate design. Same sony sensor as nikon and panafriend uses.
    Cinema DNG is big files. What i dont undetstand is why not support for higher frame rates and bad h264 flavor 422 8 hit hdmi output and low frame rates is not what modern standards are.
    Seems this is an agreement camera between brands. too many Issues when sensor can give much more thats a pitty.
  • SIGMA LCD VIEW FINDER LVF-11
    575 x 581 - 29K
    792 x 476 - 31K
    785 x 570 - 43K
    789 x 544 - 54K
    800 x 526 - 55K
    732 x 507 - 48K
    650 x 675 - 45K
    613 x 547 - 51K
    616 x 541 - 68K
  • Dedicated accessories
    • SIGMA HOT SHOE UNIT HU-11
    • SIGMA BASE PLATE BPL-11
    • SIGMA HAND GRIP HG-11
    • SIGMA LARGE HAND GRIP HG-21
    • SIGMA CABLE RELEASE CR-41
    • SIGMA ELECTRONIC FLASH EF-630
    • SIGMA MOUNT CONVERTER MC-21
    • SIGMA BASE GRIP BG-11
    • SIGMA AC ADAPTER SAC-7P
    • SIGMA DC CONNECTOR CN-21
    • SIGMA BATTERY CHARGER BC-71
    • Li-ion BATTERY BP-51
    [Specification]
    • Storage Media - SD/SDHC/SDXC memory card(UHS-Ⅱ supported) / Portable SSD (USB 3.0 connection, USB bus power supported
    • Lens Mount -
    • Sensor - 35mm full-frame(35.9mm×23.9rnrn) Back-illuminated Bayer CMOS sensor, Approx.24.6MP(6,072×4,056)/Approx. 25.38MP (6,104×4,142)
    • Stills formats - Lossless compression RAW(DNG) data12 / 14 bit, JPEG(Exif2.3), RAW(DNG)+JPEG: recording is possible
    • Movie Recording Formats
      • CinemaDNG(8bit / 10bit / 12bit)/ MOV:H.264 (ALL-I / GOP)
      • Audio Format - Linear PCM (2ch 48kHz /16bit)
      • 3,840×2,160 (UHD 4K) /23.98p, 25p,29.97p, FHD(1,920x1,080) /23.98p, 25p, 29.97p, 59.94p, 100p, 119.88p
    • HDMI External Output
      • HDMI Loop out “External recorder record: ATOMOS Ninja Inferno, Blackmagic Video Assist 4K supported
      • Audio Format Linear PCM(2ch 48kHz /16bit)
      • Recording Pixels / Frame Rate 3,840×2,160 (UHD 4K) / 4:2:2 8bit 29.97p / 25p / 23.98p 1,920x1,080 (FHD) / 4:2:2 8bit 119.88p / 100p / 59.94p / 50p / 29.97p / 25p / 23.98p
    • Focus - Contrast detection system, Single AF, Continuous AF(with moving object prediction function), Manual Focus
    • AF+MF, MF Assist, MF Guide, Focus Peaking, Release Focus Function, AF-ON, Quick AF, Pre-AF, AF during Image Magnification Exposure
    • Movie Shooting Mode - (P) Program AE, (S) Shutter Speed Priority AE, (A) Aperture Priority AE, (M) Manual
    • ISO 100-25600, Expanded sensitivity ISO6,12,25,50,51200, 102400
    • Image Stabilization System - Electronic system
    • Electronic shutter 30 to 1/8,000 sec., Bulb
    • Monitor - TFT color LCD monitor Aspect Ratio3:2, 3.15", Approx. 2,100,000 dots / Electrostatic capacitance system touch panel /Approx.100%
    • Color Mode - 12types( Standard, Vivid, Neutral, Portrait, Landscape, Cinema, Teal & Orange, Sunset Red, Forest Green, FOV Classic Blue, FOV Classic Yellow, Monochrome)
    • CINE Mode - Still image shooting during movie shooting / HDR shooting / Director's view finder
    • USB3.1 GEN1 Type C
    • HDMI Type D (Ver.1.4)
    • Release Terminal Also used as an external microphone terminal.
    • Li-ion Battery BP-51 *USB power supply available (when the power is turned off)
    • 112.6×69.9×45.3mm
    • 422g (including battery and SD card), 370g (Camera Body Only)
